Sony ZV-E10 audio noise
profile.country.NL.title
AlyssOG
Nieuw
Just purchased this camera and I notice that the audio catches a sounds that resemble the noise when you blow over a glass bottle. very annoying and not what you expect from a vlogging camera. Its the same with and without the little fluff for outside recording.
Is the camera broken or should I adjust some settings?
1 ANTWOORD 1
Niet van toepassing
Are you connection an external mic to it? Try to turn the wind noise reduction on from this link
