A33 - can't take 7 images per second
profile.country.no_NO.title
smurfine
I have just bought a sony a-33 camera.
When I try the 7 frames per second button, it takes only 1 image per second, and not 7. When I tried the function yesterday it took 7 images per second, but not now.
Can anyone help me? Maybe I have done something with the settings that I shouldn't have done.
1 REPLY 1
Blencogo
Check the following: -
  • Check that you have HI Speed Continuous mode selected.  Lo Speed will give only 2.5 fps.
  • You cannot shoot continuously when using Scene Selection modes other than [Sports Action].
  • When [Face Detection] is set to [On] or the Smile activated, the speed of continuous shooting may be slower.
  • HI mode gives about 6 fps. To shoot at 7fps you need to select Continuous Advance Priority AE (the 7 button you mention)
:thinking:
Message was edited by: Blencogo
