I have an LA-EA1 and a NEX-3, normally working with the 18-55 E lens. I want to use my 70-300 SSM G lens with the LA-EA1, but to get autofocus you need the firmware upgrade to version 2. I have downloaded the upgrade and tried to follow the instructions as closely as I can, but the process tells me it's not available and aborts it.
Does this mean that it won't autofocus with the SSM lenses, despite what Sony claims? Or can somebody tell me I'm doing it wrong?
Thanks, Thalamus
I've now realised that there are two versions of the Update software. The one I was complaining about (NEXVG10v2_Update) was actually for a camcorder and is slighty different to the camera version (LA-EA1v2_Update) which works as expected. My fault, although the support page for this product was slightly unclear. Thanks again.
Colin
Hi aswan1661,
have you followed the instructions & checked the firmware version that is installed on your camera..:smileyconfused:
Thanks Thalamus
Yes, I checked version (identical to graphic in your answer) and followed the instructions. Process aborted, as I said.
Aswan1661
Note - the upgrade can ony be performed when the battery level is
(three marks) or more..
Also did you attach the Mount adaptor and the A-mount lens to the camera before turning on the camera as instructed..:smileyconfused:
If so at what point in the following process does the update abort.?
Hi Thalamus
Yes, I have full battery and I att ch the LA-EA1 complete with the SSM 70-300 lens. Here's what happens in the update process as you show above:
I'm OK up to step 7. I click Next. What comes up now is Figure 4 (with the version information greyed out, and the Next box greyed out).
Step 8 tells me that if Figure 4 appears, I should stop the USB connection ('Safely stopping hardware', and click Finish). But if I do this, then the session is over, and I can only try again from the beginning. The rest of this instruction I have done, but it seems pointless (Turn off the camcorder! Remove the battery pack etc...)
I want to get to figure 5, but I can't see how, if I have terminated the session by clicking Finish as already instructed.
It looks as though this discussion has died without solving the problem or answering the question. Thalamus kindly offered the update instructions which I already had. Official Sony support site only directs me to an 'Access denied' URL, and I don't suppose anyone will read this now.
I'll give it a day or two and try posting again. What is the point of buying Sony products if they don't do what is claimed, andf there is no support?
Hi Aswan1661,
I've not forgotten you I'm trying to find someone who may be able to shed some light on what might be causing the problem..:smileywink:
Thanks, Thalamus
Colin
Thanks for the update, I'm glad you've managed to update the firmware..:smileyhappy:
Ahoy!
I know this is an old thread, but it might be useful to others who may be experiencing the same or similar issue.
Although I don't use the E-Mount, I do have a Sony LA-EA1 lens adapter and having done a little research, I would suggest looking at your regional Sony website for any new firmware, and in addition, make sure you're using the correct lens adapter, and you can see all the info relating to each model and how they differ on this Sony chart and there's a real handy Sony lens/body compatibility chart here as well.
I hope this may be of use to anyone reading this thread.
