The mirror on my A77 has what appears to be a small spot of grease on it. This appears on photos where it is on an area of bright sky as an out of focus grey spot. Can anyone suggest how to clean the mirror without damaging it? The only cleaning instructions in the manual refer to cleaning the sensor.
Hi sjhughes
Sony warn against touching the a77's mirror, and I can only reaffirm that note of caution. It's very easily marked and should be treated with at least as much care as the sensor beneath it.
The reason you see the spot on your images is that the mirror is of the 'pellicle' type which remains in place during exposure. This is the primary reason why you should never touch it, as it lies in direct path of the image and any/all marks on it will show up on your shots to some degree.
Treat it as you would the sensor: dust may be dislodged with a blower brush, but if you have something stuck it, take it to a decent camera store and get it professionally cleaned.
If you need advice for removing the mark from your photos, just ask
Mick
Hi sjhughes
Mick
Just in case I do this, what is the replacement part number and where can it be ordered from in the UK?
Many thanks
GB
The part number of the translucent mirror is The part number of the translucent mirror is A-1855-640-A and can be purchased on Sony's parts website at the following address:
www.servicesplus.sel.sony.com
Your requested quote is as follows:
Date of quote: 05/09/13
Account: NA
Quote number: 050913TH
Part number: A1855640A
Part description: P.O.I (SERVICE)
Price: $ 33.42
Availability: In stock
Hi Guys can you tel me the exacxt ocst of a replacemnet Sony A77 mirror including postage to postcode...SO304SL UK........and how you accept payment ....kind regards John
You could just buy it from this Amazon seller:
http://www.amazon.co.uk/Sparepart-Sony-P-O-I-Service-A1855640A/dp/B00B184HLI
