hi,
looking for a not too big external flash for the nex-6 -- any ideasa?
regards
Hello canach2012 - Welcome to the Sony Forums
As this is naturally a compact camera, you may find that attaching an external flash makes the whole setup a little 'top heavy.' Having said all of this, the camera does have a standard hot shoe, meaning that it will be compatible with a variety of lenses (in some cases, an adapter will be required). The HVL-F20 flash is around £100:
http://www.amazon.co.uk/product-reviews/B0057XBH70/ref=dp_top_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
For this particular flash, you will also need to purchase an ADP-MAA adapter. These are available online for around £20-£25.
Thanks,
Simon
UPS, this can be confusing as there are actually 3 different HVL-F20 around:
Many thanks to all...
So best will be to wait until end of may when the F20M will be available...
regards
Klaus
Hello again
Thanks for the additional input cmosse
Simon
