Comparte tu experiencia!
Please ignore this it was a dumb question that I've just found the answer to.
Message was edited by: scon4061
Hello scon4061
If it is convenient, could you post up your original question and how you solved the issue so that other people can read it in the future if they experience the same problem?
Thanks,
Simon
