After change of my disc drive I had to reinstall the entire operating system and applications. By reinstalling PMB I realized that I lost all my comments to the pictures I made in PMB. Is there any way to store these comments and import them after reinstalling PMB?
Hello stahula - Welcome to the Sony Forums
I am not sure how PMB would function in this respect but I would imagine that this would be possible as long as you have backed up the images.
If you do not get a sufficient answer here, there may be additional support available on the PMB web site which is available here:
http://support.d-imaging.sony.co.jp/www/disoft/int/pmb/index.html
Thanks,
Simon
There is a tutorial available for Abckup and Restore the PMB database when moving from one PC to another (or changing disc I assume)
However I do not know if the comments are can also be restored in this way
http://support.d-imaging.sony.co.jp/www/disoft/jp/pmb/feature/backup/backup.html
A basic translation of this guide is available, which is attached as PDF file
