Hello all,
I am running into an issue.
I have a Sony A7r4 bought used with 15,000 actuations.
I purchased a Sony 90mm Macro lens from KEH about a year ago, new.
Recently over the past few days when I attached the lens to the camera, I am getting an error.
When looking at the rear display on the camera I notice the aperture will show and then go blank then comes back and goes blank again.
Not sure what is going on.
I have not dropped either the camera or lens. Nothing has gotten wet.
Currently the camera is on Version 1.20. I am not sure about the lens.
It works intermittently and I am able to take pictures sometimes.
When the Aperture in going in and out I can hear the motors inside moving.
Any advice or assistance would be appreciated.
Thanks in advance.
Mike Romano
Hi @Romano1303 I checked, and the lens is fully compatible with your camera: https://support.d-imaging.sony.co.jp/www/cscs/lens_body/?mdl=ILCE-7RM4&area=gwt&lang=en_GB. Try some troubleshooting steps with the camera like initializing the camera: https://helpguide.sony.net/ilc/1930/v1/en/contents/TP0002688489.html?search=reset
