Hi i bought my sony nex-5 in usa, and i want to choose russian language.There is no russian language in the menu. Where can i download russian firmware or some upgrade (firmware v3 didnt help me).
Hi nemovich,
welcome to Questions & Answers..:smileyhappy:
I believe you can install European Firmware, which should include the Russian language.
You can download the firmware by using the following link http://support.sony-europe.com/dime/downloads/downloads.aspx?site=odw_ru_RU&f=FW_NEX5_V03_WIN&m=NEX-...
You may need to set the language to “Pyccknn” in the Set-Up menu..
Hi nemovich,
Hello Thalalmus,
Have the same problem and tried your suggestion. No that doesn't change anything. Any other suggestions? Anyone?
Thank you!
