hi,
can some one please help, once i put the self timer on, i only get the option to toggle it between 2sec. and 10seconds. i can't find an option to turn it off . i resolve to resetting the camera every time.
may be i'm missing something!!
can some one please help?
thank you
I don't have the A37 but my A77II will be similar.
You are going into Drive Mode to select the Self Timer. Go back into Drive Mode and select Single Shooting to turn it off.
Register at http://www.dyxum.com/dforum/amount-apsc_forum29.html and ask away about the A37 functions, it's a dedicated Sony forum and we area friendly bunch honest!
Ed.
Ed.
Ed!! you're great
thank you very much!
