Hello,
I have this Bluetooth headset and I am happy with the performance over all but when I use them for a meeting the microphone captures more ambient noise that my own voice,
my question will be, is it possible to install an external boom microphone via the 3.5mm input jack?
Hello @Ibattis,
you mean connect another microphone and still use it wirelessly? No, that is not possible.
You can though get a microphone/cable with inline mic which has a TRS connector on the side of the headphones and a TRRS connector on the side you plug into your PC.
- Nic
Hello @Ibattis,
- Nic
Exactly the answer that I needed, thank you very much.
