1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
Hope not! Mine was set to auto download in the background so it would have done it either way.
65% done at the moment... Could still cancel...
@MrLizard.... was thinking the same thing! For those in the UK doing the update, are you manually doing it, or auto? I am in the mind of turning off auto until this is a confirmed fix!
I had to do a manual update, but its definitely happening!
OK, update downloaded. Just kicked off the installation. See you on the other side!
Could it be because of all the complaints they've decided to launch what was working in the firmware yesterday and left the bit they found an error in out?
I have a KDL-43W807C and I'm getting an update now.
It would seem that the pressure on Sony to release something on todays promised dealine was too great and they have released an update of some sorts after all.
