1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
I'm on the latest firmware. Prior to that I had experienced relatively few problems at all. Notably the HD channels -– not being able to control the volume from my Humax remote, (something my old Sony TV would allow).
It's a great TV picture and the product design is exactly what I wanted.
But ANDROID TV is a disaster...
And another thing.. Why the F*** cant I add SKYPE as an Android App and buy a camera for the TV so I can use whole TV for SKYPE??!!
Is it really that hard?
Sideload Skype onto it, i had to with SKYGO
sorry for late reply... was in London all weekend
interesting read i read there isnt a dual tuner so cant have youview with satellite? one deletes the other? that is odd
what have youview said on this issue? nothing i bet!
Yep, looks even better after the latest update...
and yeah keyboard / mouse to navigate
you cant update app, but i just extract it and update manually
