43XG8369 technical parametrs
Normiks
Where and how can find real technical parametrs from TV inside? RAM GB 16 or 8 ?, Processor name, frekvence Hz 50 or 100? , etc? I not sure, that my 43xg8369 are with the parametrs, as descripted in manuals and broshures.
4 REPLIES 4
profile.country.NL.title
pa3eia
I think you mean the XG8396?
Look at the specifications .
73's
Thanks about the Kudos!!!
Normiks
Thank You. In paper I know this parametrs. But how can see real in Tv its? For sample- in paper have 16gb ram, but tv settings visible to me 8ram. With native Hz 100w is more interesting, this value not visible in tv, and not possible change from 100 to 50 etc, therefore how customer can know, that tv have the same parametrs, which is in paper? Maybe in paper was 16gb, 100hz, but customer bought tv with 8gb and 50hz...  In each computer can find inside real parametrs, but how can find these parametrs/data in this Tv?
Marino.Manolo
LCD with Motionflow XR 1000 Hz (native panel frequency 100Hz)
Total internal memory 16 GB, 8 available to the user (expandable via USB with Flash memory or HDD)
Normiks
can these settings/parametrs (100hz, 16gb..) be found somewhere in the settings using the TV and the remote?
