Any way to access Sony EPG once YouView installed
TonyKD49X8309C
Is ther any way to access the Sony shipped EPG program guide once the youview app is installed without having to go back to factory settings?
1 REPLY 1
Not applicable
Hi there
All you need to do is disable YouView
To disable YouView
  1. Press [Home] button on the remote control
  2. Go to 'Settings'
  3. Go to 'Channel Setup'
  4. Go to 'YouView Setup'
  5. Select 'Disable YouView'
  6. Select 'Yes' to confirm
Same process to re-enable it again.
