best tv settings for sony bravia KD-49XG9005
Hi just bought the above tv and what are the best picture settings to use,thanks
1 REPLY 1
LightFoot
Specialist
Hi @pauldormer   The best picture settings are what looks good to you. Everybody is different, so I simply use the default standard. It doesn’t matter what settings you use, your eyes soon get used to whatever you decide and it soon becomes the norm.
