Hello, doesn't Bravia 7 show what % battery the remote has? In Chromecast it showed me what % battery the remote has but I can't see it here. I have the original remote SONY RMF-TX910U
Hi @Krzysztof31
Having had Sony TVs for the last 40 years I have never seen a remote battery % display, only low battery warnings. Below is from your TV’s web user guide.
Ok thanks 👍
You'll be surprised here, my friend. I got the rmf-tx920u version of the remote yesterday and it shows the battery status of the remote :). So the newest remote supports this function, the older version doesn't
@Krzysztof31 wrote:You'll be surprised here, my friend. I got the rmf-tx920u version of the remote yesterday and it shows the battery status of the remote :). So the newest remote supports this function, the older version doesn't
Hi @Krzysztof31 Something new, any chance of an image.
Yes, I'll send it later 👍
