- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Does XG9005 work with Sonos Beam?
The height of the Bean is only a mm or two lower than the IR sensor. I'm wondering if anyone has had issue with it blocking the signal. Also, I read on another post that some people have issues with Hdmi Arc connection. If you have any suggestions I'd appreciate your thoughts...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi DavidLB,
If the soundbar is lower than the IR sensor there shouldn't be a problem with the remote.
In terms of HDMI connection it should work fine. However, we have some customers that faced issues with their Sonos product in combination with Sony TVs
By the way, the HT-XF9000 is also a great soundbar and fits nicely under your TV:
https://www.sony.co.uk/electronics/sound-bars/ht-xf9000
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Peter,
Thanks for your reply. I've looked at that specific Sony sound bar but my XG9005 doesn't have Dolby Atmos /eArc so I presumed I wouldn't benefit from the sound bar's Atmos feature.
