To All
The intent of this thread is to provide the Sony Communiity with some general troubleshooting advice for people who are experiencing issues that are related to a device that is connected via HDMI. Below are 4 steps that should resolve many issues. If the do not, see the advanced troubleshooting section.
#Note: When you plug or unplug HDMI devices, it is best practice to switch the devices off completely.
Step 1 - Handshake
One of the most common causes of devices not working via HDMI is what is commonly referred to as a ‘HDMI handshake problem’. HDMI Handshake is the process of each device recognising and authorising each other in order to send signals between devices.
If this process should fail, the easiest solution is to power cycle all devices – meaning switch everything OFF from the power socket on the wall. Leave OFF for about 30 seconds and switch on again.
Step 2 – Loose Connection
If Step 1 does not resolve your problem, you will need to check if the HDMI cable is securely seated correctly. It is possible that the HDMI cable has dislodged itself, due to any number of reasons. Switch all devices OFF and check that the cable is fully inserted into the correct HDMI port. Sometimes its best to unplug it and re-plug it back in again.
Step 3 – Replace Cable
If the above 2 steps fail, try replacing the HDMI cable with another one – preferably a decently shielded HDMI cable. If you have a spare HDMI port, try using this too – incase there is a problem with the actual port itself.
Step 4 – ARC Issues
This step is specifically for people who are having problems with ARC (Audio Return Channel) on connected sound deviced such as Soundbars, AV Receivers and Home Theatre Systems. The above 3 steps should fix most problems but if not, sometimes the ARC needs to be enabled in the settings of the device.
The specific setting for ARC is generally located in either the HDMI settings or the ‘Control for HDMI’ settings. Many devices require HDMI-CEC (Control for HDMI) to be enabled in order for the ARC setting to be enabled
Also ensure that Bravia Sync is enabled on your TV if it is a Sony (or equivelant HDMI-CEC name on another brand)
Advanced Troubleshooting
If all of the above steps have failed, this is where thing become a little bit trickier and requires time and patience. The purpose is to identify which device is causing a conflict and preventing other HDMI devices from working.
At some point you should come across the device that is causing the issue. Once you do, try the following to see if it helps:
At currect, this community has identified 3 devices that can cause conflicts. These are:
Hopefully this had helped
