Headphones and sharing TV sound
ROZWIĄZANE
DragonPip
Poszukiwacz
 KD43XD8305 and headphones. I have severe tinitus and need TV louder than others in room. How can I listen with them through headphones and they can still hear TV?
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
Caermead
Użytkownik
@DragonPip
Hi,try this if you want to use headphones connected to the 3.5mm output socket :-
Home > Settings > Sound > Headphone/Audio out.....change it to...Audio out (fixed)
And also change :-
Sound > Headphone speaker link to.....On
The above comes with a warning --YOU MUST use headphones with their own volume control,
because setting it as above will give max volume output to the headphones independant of the
tv controls.
:cool:
Wyświetl rozwiązanie w oryginalnym poście
2 ODPOW. 2
Caermead
Użytkownik
@DragonPip
And also change :-
tv controls.
:cool:
DragonPip
Poszukiwacz
Thank you Caemead
I found the audio out and saw both variable and fixed.
I got rechargeable RF cordless set of head phones with own volume control
Got both size adapters too
