I have the KD-49X8305C and for some reason the info banner will not disappear after the TV is initially turned on.
It's the one that shows the time and the HDMI input .
Anyone else had this, any solutions to it
Thanks
Hi @sehuxle
Have you tried turning the info banner off in Settings?
Go to Home, then settings, channel settings, infobar and then select 'off'.
Hope this helps
Hi @sehuxle
Hope this helps
Many thanks, that removed the banner completely.
I looked at various menus but not that one.
Hi again
No worries, glad its sorted
