I've recently bought a KD50X85KU and i'm getting used to it, but one problem that persists is the behaviour of the input menu on start up. It takes ages to work properly: for several minutes it is incredibly sluggish and buffers commands for maybe 5 -10 seconds before performing them. Eventually it works fine. Is this a 'feature' of 'smart' google TVs or is the set defective?
Thanks for any assistance.
Thanks for the suggestion. I updated the firmware and the problem seems to have disappeared.
Hi @bully9 I would be inclined to perform a soft reset and if that doesn't work, a full factory reset.
What happens if you remove all of the HDMI inputs, just in case an external device is causing the delay.
Hi - and thanks for replying. I thought i'd give it a further period unplugged before going through the long and time-consuming set-up process, especially as i've just completed the initial one. It seems to have sorted itself a bit, although it is still slightly sluggish until it 'warms up'. I thought it may have been a common problem, but judging by the responses it is not.
BTW i have PC, laptop and HT receiver on the 3 inputs, exactly the same as my old TV, so i guess there shouldn't be a problem there.
Brilliant! Thanks for updating the thread with the solution!
