iPlayer will not work on KD-49XG9005
Pebbleridge
I think it was yesterday that iPlayer wouldn't open.
We left it overnight (in case it was tired :slight_smile: but it still isn't working.
Has anyone else had this recently?
I've tried all the usual tricks, turning off and back on again, but I don't fancy doing a full reset unless I know for certain there is no other way.
Regards,
Paul
2 REPLIES 2
TheGOAT
Hi @Pebbleridge,
You can try these troubleshooting steps:
- Press on settings > Apps > LiveTV & CatchUp > Uninstall updates, Force Stop.
- Press Home > LiveTV & CatchUp > Apps > BBC iPlayer
- Make sure that your TV is on the latest update
If the issue remains, the final option is performing a factory reset: https://www.sony.co.uk/electronics/support/articles/00274122?link-header
Pebbleridge
Thanks for your suggestions, which are "similar" to the advice I received from Sony technical support.
I tried everything but one thing that Sony suggested I hadn't tried and that was to physically unplug the TV for a few minutes.
Base on their advice but expanding it to incorporate my thoughts (it might be network related, even though the TV said the Internet was OK) I also physically unplugged my Broad band, router and network switch.
I turned everything back on and it iPlayer is now working again.
So fingers crossed I have now resolved the issue.
Thanks for your advice I have noted the options you gave in case of future problems.
Regards,
Paul
