We bought a KD-55XD9305 about 6 months ago. Tonight it is doing nothing when we try to turn it on using the remote. No lights flashing, nothing, it's like the TV is completely dead. This happened once before and following the troubleshooting instructions in the manual I turned it off at the mains and on again and this resolved the issue. Tonight we have turned off and on at the mains, checked the wires into the back of the TV, tried the on/off switch on the TV itself, and have changed the batteries in the remote. Still nothing at all happening. Attached sound bar turns on and off no problem.
Can anyone please advise or help? Many thanks.
Hi @bmb7jiw
Does your TV have an external Power Adapter ?
If so, try removing both 220V AC adapter from wall and 24V DC adapter from TV.
Wait for 1 minute and replug both of them.
If not solved call Sony Support for a Technician in your area
Me too, March 2016
Me too!
Mine had to go back to the dealer for repair. Sony ended up replacing it with a new one....
Ive moved this thread to the Android TV board and linking to this main 'master' thread:
https://community.sony.co.uk/t5/android-tv/xd9305-loss-of-all-power/td-p/2266186
Thanks for the response this gives me some hope. Have had to wait 6 days for the engineer visit, they are coming on Tuesday.
I bought this TV from currys pc world in oct 16 and 3 weeks out of the box it failed i.e. Nothing tried would get it to turn on. I rang currys pc world who in hindsite should have replaced it but I was pushed to Sony as the TV came with a 5 year guarantee. The TV was returned to RRC in Birmingham who returned it working but with damage to frame and stand. Eventually Sony replaced the TV in December and now in April 2017 the new set has the same error. It's going back to RRC tomorrow and I await its 'safe' return. The PCB is at fault and Sony say it's 2% fail rate and will not recall the product. I have had 2 sets both with this issue.....in my opinion it's a 100% fail rate ? Any further issues and I will demand full refund plus costs and give Samsung a go as I can't fault the set I have had to buy so that I can watch something whilst trying to get Sony support in Egypt to understand the problems and RRC in Birmingham to collect/repair/return the set.
My KD-65XD9305 will not power on. had it just under a year literally.. what can I do?
Hi
If you have tried the suggestions in this thread then I'm afraid
the only option is call Sony Support on +44 (0) 2073652810
(especially if its still in warranty
