Kd55-a8g irblaster with sky had box
Gussie2769
Hi
i just installed a new KD55-AG8 connected to a SKY HD box.
Most things work fine but the Ext Box Menu button does not produce anything.
Also the arrow buttons withheld TV guide seem to send 3 updates instead of one so channels are skipped when scrolling through.
I saw on the forum that this issue was common in 2016but should have been fixed in 2017. Is it still persisting?
cheers
2 REPLIES 2
Pascale_F
Hi Gussie2769,
Welcome to the community.
I'll look into this for you and see if I can find out. Someone else in the community may be able to advise in the meantime.
Thanks,
Pascale
Win_88
Specialist
Hi Gus,
There are a couple of things to try/check regarding the performance in the guide:
  1. Go to Settings - Storage and reset - Internal shared storage - Cache - Clear
  2. Press and hold the power button on the remote until the TV restarts.
  3. Make sure the TV is up to date: https://www.sony.co.uk/electronics/support/oled-tvs-android-a8g_ag8-series/kd-55ag8/downloads/000162...
I'm not sure what to do about the menu button on the Sky HD. Maybe Sky can shed some light on that
Win_88
