KD55XD8005C and ps4 pro (HDR is not supported on your tv)
ivoc90
I have sony xd 8005 c. It is said that it is HDR tv. When I connect it with ps4 pro, in settings it is said that resolution is 3840x2160, 60 Hz, colour format is RGB, but HDR is said that not supported on my tv.
So, I
Check the PS4 video settings are to auto.
In tv settings put HDMI (all 4 of them) to enhanced mode
Swapped cable over to all 4 HDMIs
Checked that TV has the latest firmware update.
I am using the correct HDMI cable, the one that came with the Pro.
Even tryed to put ps4 to safe mode and put HDCP on 1.4
Anyone has any solution?
Thank you.
5 REPLIES 5
kdombaz
Please see this thread https://community.sony.co.uk/t5/android-tv/netflix-hdr-firmware-update-12th-april-kd49x8005cbu/td-p/... . I have the same TV (49") and I know it doesn't support HDR.
Sorry to dash your hopes,
Koray
A "D" can make such difference. My bad ppl.
Budhi108
in thread you link is about x8005. and this is about XD8005
xd8005 have HDR
https://www.amazon.co.uk/d/Home-Cinema-TV-Video/Sony-KD55XD8005-Android-Freeview-PlayStation/B01IF52...
kdombaz
I'll take a punt here and say do the following
reset tv
keep all hdmi'd to standard.
reset ps4
use a different hdmi
keep all settings to on PS4 video out and TV as defaults
connect to hdmi1 get 1080p
change hdmi to enhanced and see what happens
I hope this helps.
Koray
ivoc90
Nothing seems to help. TV is now in repair, it is something wrong with it.
Koray, thanks a lot for your time..
kdombaz
Just over Xmas as well. Hope it gets repaired quickly.
