Can not scroll back 7 days anymore and ITV 1 Hub keeps asking for postcode even though it has been entered. Are they both connected ? Had a 24 hour power cut at the weekend, not sure if relevant. On scroll back says no information, will scroll back for the current day but not previous days. Says software is upto date - TV is latest Sony 49" . Was working fine on scroll back (never previously watched ITV Hub).
Well done and thank you it solved my problem
Cleared cache and data as suggested and is now working let's hope it keeps on working as these Sony TV s seem full of problems and is less than a year old.
thanks very much - it worked!
This solved my problem hub is up and working again Many thanks. !!!!!!!!!!
Brilliant!!! It worked for me, thank you so much 😄
Brilliant,thankyou
Fantastic and thanks, it worked for me.....but why should we have to do this to a Sony smart TV...it's not that smart then, and neither is Sony
Thanks so much, it woorked for me too!
After clearing cache and data it still didn’t work. So I cleared them again then turned off the TV and turned it off at the mains plug so that it shutdown fully and would reboot when I powered it back on. After powering it back on itv hub worked fully again and showed me the main ITV channels :). I could then watch Quiz.
