This morning I tried to turn on the television and nothing. I unplugged the power, gave it a few minutes and replaced the power.
Still it would not turn on.
We then noticed the small red led. That led has never lit up before, we didn't even know there was a red led.
All we have ever seen is the white light at the base of the set.
I unplugged again and left it for 5 minutes. This time, the set turned on using the remote.
The red led is still there and the television seem even more sluggish than after the previous software upgrade.
I have done a quick google and can only find a reference to a red flashing led. This red led is not flashing.
Anyone any ideas?
I know what the red light indicates.
I reactivated (temporarily) the Google voice thingy.
I have now deactivated it and the red light has gone.
Hi, could you tell us the current software version you have on it?
Glad to hear it was resolved for you!
Be sure to mark the thread as solved so others can find the solution easily.
- JD
