Remote control audio button
anparnh55
Can anyone shed any light on what difference pressing the audio button on does on the remote control. Namely on the XF9005. Each press changes from audio A, B and Dolby digital stereo. Will A and B just be mono ?
3 REPLIES 3
IamNic
Hello @anparnh55,
that depends on which audio-tracks the TV-channel you are watching supplies.
A would be "normal" stereo, B could be audio for hearing-impaired and the last track is self explanatory.
- Nic
WDGlover
Not right.
‘blank’ is stereo
A is mono something.
B is mono something else????
WDGlover
Section 6
  • Audio button: Select the sound of multilingual source or dual sound for the programme currently being viewed (depends on programme source)
found it!!!  Bit vague.
