Hi all,
I have decided that the Sony Bravia KD55XH9005BU is the next TV for me. But i need to confirm that my Bluetooth headphones will connect to it!
I have the Sony WH-1000XM3 headphones.
I have looked around online for an answer but i just don't seem to trust what I've read...
I've seen that it states that my headphones will work on 2018 models, but does that mean they will also work with the 2020 models? i assume so, but I'm not spending £1000 for it to not work.
Any advice would be appreciated
Thanks
You'll never find a list of tested headphone as you won't find on a smartphone but XH90 is A2DP capable and BTW your WH1000XM3 works fine on my "old" A1
Hi rich,
Please check the following article:
The XH90 supports your headphones as well.
