Sony Bravia KD49XF9005BU part 2
webb01
Hi all my Sony Bravia KD49XF9005BU new remote control doesn't work is there something i haven't done should do to pair it or something, or could it be tv itself ? ...... see link ..... for story so far if i did link right?,
the remote i downloaded to galaxy s9 still working tried turning it off, remote still not work any ideas ? cheers
2 REPLIES 2
webb01
just bin thinking ...... does the app on my phone use bluetooth to connect to tv? ..... where as my remote, and new remote uses infrared? ..... so is it infrared on tv broke ? could that just happen ? or more likely software ? update
webb01
sorry been meaning to update this for a while, i pressed (Accept as solution) in part one by mistake see above, the real solution was to get a new mainboard plus lots other bits on invoice, luckily this was still under warranty, and cost more than half what i originally paid for tv, tv still under warranty hope it doesn't just do it again, hope this helps anyone in same situation
