annulla
Cerca invece
Intendevi dire:
Sony Bravia w800c Downgrade Help
sarjil
Esploratore
Is there anyone willing to help me out.I have got  sony bravia w800c tv from malaysia. By mistakely I have updated the firmwire.cause of latest firmwire update its cause alot of bug
1.3D setting sometimes show sometime don't while playing  from USB
2.Action menu does not work most of the times
3.3D glass pairing does not work
Is there anyway i can downgrade firmwire please help me guys
I will be really thnaks to you
Tag (1)
1 RISPOSTA 1
Non applicabile
Hi there
You cannot downgrade the firmware im afraid.  You can update it if the version is higher than the one installed.
  1. What country are you located in?
  2. What country firmware have you installed
  3. What is the current firmware version installed at the moment?
