Sound lag?
Jiw237
Sound lag?
A couple of weeks ago my 2yr old Sony kd-55x850 tv updated and since then there has been a approx 3-4 second delay after playing anything off my sky hd, it happens after fast forward or rewind too.
strange thing is i have magic eyes linking other TVs but they work fine.
its pretty frustrating after a while as you miss starts of conversations etc lol
anyone else had this issue
thanks in advance
8 REPLIES 8
EdwinaU
Hi there,
Could you let us know the exact model number and we'll try to find some advice for you?
Best wishes,
Ed
Jiw237
Pascale_F
Hi Jiw237,
It might be worth performing a reset on your KD-55X8509C TV. You can follow the instructions here to do this.
Thanks,
Pascale
Jiw237
Yes i have done this at the weekend but unfortunately it is still the same, it seems to have happened since i last updated it
EdwinaU
Hi Jiw237,
I'll look into this and get back to you if I find more information. Meanwhile, perhaps another community member will have some ideas.
Best wishes,
Ed
batee5
Specialist
Hi Jiw237,
Is it possible to try connecting the Sky HD box directly to the TV without using the magic eyes setup just to check if it will do the same thing when connected directly? Also, have you checked if other external devices have the same issue with the TV as well?
Let us know the outcome if you tried those tests.
Regards,
Batee5
Jiw237
Hi thanks for reply
the tv is connected directly the magic eyes are connected to other TVs on the house and wierdly they all work fine
i have a PS4 which is connected to this tv so will try and see if that has the same issue
cheers James
TobiasRieper315
Please see here:
https://community.sony.co.uk/t5/android-tv/sound-delay-changing-channels/m-p/2453049#M27217
Issue that is already known but still present and not fixed.
I am still waiting for Sony Support to update me via email with a resolution/fix/update ...
