Wall install power brick solution
micallefgilbert
 I just purchase an XG83 series and I installed on the wall. I placed the power brick behind the tv between the wall and back of the tv. Is not touching the tv. Is this ok? It has plenty of ventilation. I did this because I have prepared a power outlet behind the tv.
I am asking maybe it can affect tv.
Thanks
5 REPLIES 5
IamNic
Hello @micallefgilbert,
I would say that neither the TV nor the power brick will get too hot.
If you have concerns, I would purchase/lend a infrared camera or laser thermometer to check what the maximum temperature is.
- Nic
micallefgilbert
Thanks Nik for the reply. Apart from the temperature i was more worried that the power brick can have some magnetic field that can somehow effect the tv. Thanks
IamNic
The magnetic field around power bricks is rather weak, also aside from cathode ray tube TVs the newer panel types aren't really affected by magnetic fields anymore from what I can tell.
- Nic
micallefgilbert
Thanks very much for your time!!
IamNic
you're very welcome.
- Nic
