annulla
Cerca invece
Intendevi dire:
XD70 and dh520 no sync so sound via hdmi
olegjeler
Esploratore
Does anyone have a set of TV  XD70 and receiver dh520?
I have a problem, bravia sync does not work. TV in any case does not see the receiver.
 I can only send sound to the receiver via optics.
 PlayStation 4 works with sync perfectly, visible in the list is controlled by the remote. (mean sync is work)
I tried all the settings of the receiver (of course, the control is enabled), tried different inputs and outputs.
The receiver is in the list of supported models for TV, but sync does not work, the HDMI icon is active
As a result, I cannot transfer audio via HDMI from a TV
the only time the sound went through HDMI when connecting xbox 360 via HDMI to the receiver, and the receiver to the TV also via HDMI (the passthrough worked)
tv have last august update
ps on optics, the sound only from the built-in player goes to DTS and DOLBY, kodi and others are all in PCM (regardless of the audio output settings from the TV).
11 RISPOSTE 11
olegjeler
Esploratore
one thing. if bravia sync active. i can use remote from dh520 for TV. magic. but receiver not listed on TV sync .
EdwinaU
Hi there,
Welcome to the community.
We'll check this and get back to you when we have more information. Maybe some of our members will have some experience to share.
Best wishes,
Ed
olegjeler
Esploratore
will be nice. because I'm at a loss as sony  TV is not "friends" with sony reciever
Win_88
Specialist
Hi Olegjeler,
Have you tried resetting the amp? The steps can be found on page 29 of the manual here: https://www.sony.co.uk/electronics/support/res/manuals/4263/42633611M.pdf
Win_88
olegjeler
Esploratore
yep. "cleared" but in bravia sync list  amp is missing and TV sound sending to amp only via optic, i'm try factory reset TV too.
one else, if I connect xbox 360 to "game" hdmi port on the reciever and passthrough on to TV, the receiver via HDMI/ARC  send only video to TV without sound, I can check it if set "sound out" in tv audio setting to the tv  speakers ( but maybe it should be).
the remote from receiver operate with TV with only optic conected and without hdmi :), but with only with bravia sync on
only next solutions left
- different HDMI cable (but i think that HDMI cable from  PS4 pro suitable for ARC ).
- broken HDMI/ARC on TV or on receiver
- TV software problem....... becouse I tried almost all the other options
Win_88
Specialist
Hi again,
At this point I'd try going back to basics:
-Make sure all devices are running their latest firmware.
-Try having only the TV and amplifier connected to see if any of the audio issues will happen.
-If possible, try connecting a sound bar or any audio output device to the TV via HDMI to make sure it outputs audio.
-Definitely try a different cable.
Win_88
olegjeler
Esploratore
TV - last update, amp - hmm - how i can check firmware on it?
Try having only the TV and amplifier.....
- nothing in any combination with my all devices.
if possible, try connecting a sound bar or any audio output....
- will try to find, but now i have only xbox/ps4/laptop they can send video and audio and all TV HDMI ports can take it and play via TV speakers. today I can't and i don't know how to check ARC function of my TV or dh520. But why bravia sync don't see dh520? I think it two problems in one point.
Win_88
Specialist
Now that I think about it, you can also test the amplifier with another TV if you can (using HDMI) which should be very insightful.
Win_88
olegjeler
Esploratore
so, check with another TV and good 2.0 hdmi cable...... nothing..  Problem in amp HDMI/ARC out port.... way to service 😞
