Battery Problem
Deva1927
Battery Problem
My xperia c3 ,drain very fast,80% shutting down
14 REPLIES 14
ChloeS
Contributor
Hi @Deva1927
Welcome to the community!
Can you test your phone in safe mode and see if you still have the same problem?
Let me know Slightly_smiling_Face
Wafaa18
The battery is sometimes disconnected at 30% and sometimes at 60% and 70% at the time. It is assumed that the battery has remained at 0% and it is separated without any preconceptions. I need to walk the charger when the first thing is done.
GT
ChloeS
Contributor
Hi @Wafaa18
I've used google translate to translate your question, please note this is an English only forum and to reply/post in English from now on.
As mentioned above, have you tested your phone in safe mode?
Try this and let me know if you have the same problem Slightly_smiling_Face
Wafaa19
Sorry for my language in arabic
 How can i apply safe mode ?!
My battery is turned off in half an hour i have to connected it with the charger 7 times or more in a day it turned off when gets 30% sometimes in 50% or 70% and i must charge the phone to start up again or it will be off alwayes how can i treat this problem ?!
Uliwooly
@Wafaa19
Tap/Click >>> safe mode
Wafaa19
I have already apply safe mode and the charge were 90% then i used my phone for 4 hours and it was good but when the phone get 55% in the safe mode it shut down again for low battery 0% what should i do ?!
ChloeS
Contributor
Hi @Wafaa19
I'd suggest trying a software repair using Xperia Companion.
Let me know if the issue still remains after this Slightly_smiling_Face
8008657541
Yes my phone battery problem
ChloeS
Contributor
Hi @8008657541
Have you tried the steps suggested above?
Let me know Grinning_Face_with_smiling_Eyes
