you mean heat? does the phone overheat when you charge it?
try to remove the phone from the charger for a momment.. till it becomes normal temp.
restart your device
then connect the phone again to the charger.
Ok, got a little bit more information,. it seems this is a hardware problem..
http://appuals.com/best-fix-charging-paused-battery-temperature-low/
http://forum.xda-developers.com/showthread.php?t=2779699
I suggest you take your device to your local service center Local support
bord is perblem.battery is ok
