Bluetooth not connecting to blue ray player
Binoo
Bluetooth doesn't connect to Sony devices ,which is shocking .I connect it in my car it works fine. When I try to connect it to my blu ray speakers first of all it takes very long to connect, whereas other non-sony mobiles connect immediately ,and then after connecting the songs  start jumping and it becomes difficult to listen ...kindly suggest solutions for this problem at the earliest
0 REPLIES 0
