Mi celular es unSony xperia c4, luego de que hice las última actualización de software que es la que me aprecio quedando en la versión de Android 6.0, comenzó a fallar, se descarga más rápido y el parlante o bocina suena muy bajo a diferencia de antes
My cell phone is a Sony xperia c4, after I made the last software update that is the one that I appreciate being in the version of Android 6.0, it started to fail, it downloads faster and the speaker or horn sounds very low unlike before
GT
This is an English only forum,
Is the volume lower with the music app or with other apps?
As for the battery try this
Provide the following screenshots
follow the steps
Charge the phone 100%
use it as you normally would
once the battery has reached 10%
Settings
Battery
take a screenshot of this
Menu
Consuming apps
Show all consuming apps
take screenshots of the list
tap on the top 5 items/apps on the list and take screenshots of each
post them all here
