There is a some drops of water inside my screen display how can i remove ut?
vivek8
1 REPLY 1
profile.country.LT.title
EUPHORIC2017
Write to Sony Mobile support or to bring smartphone to athorized service to clean these drops. I recommedn you don't use yours smartphone if is water inside smartphone and don't charge it at all, the best solution is to keep in turned off. Water can damage yours smartphone, even if smarphone will be in use. This model havn't protection from water or dust Slightly_smiling_Face
