Hi!
I can't connect my handycam to the computer anymore. I was told that my connection DCRA-C150 is burnt and this type is not made anymore. Can I get it somewhere though? Or is here another way how to put my videos on the computer?
Thanks for the answer.
You can still get them but they are expensive: -
http://www.chsinteractive.co.uk/electrical-components/misc/dcrac150-docking-station-cradle-sony.htm
Have you tried connecting the camera directly to your computer - missing out the docking station?
If you tell us what Operating System you have on your computer and what software are you using to import the movies, I'm sure someone here can advise how to connect direct.
