- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
							Problem with recording 4K on sd card
I just bought an FDR-AX33. I had micro sd card(with adapter) before - it's Samsung PRO 64GB microSDXC (https://www.cameramemoryspeed.com/reviews/sd-cards/samsung-pro-64gb-micro-sdxc-memory-card/).
Camera refuse to record in 4K with the highest quality(100Mbps) - it says "Cannot record. Please use UHS-I U3 compatible memory card"
Problem is that my card should be good enought, it is UHS-I and U3. Minimal writing speed is 30MB/s so its still about 2 times more than needed, 100Mbps it is only 12,5MB/s, right?
Any ideas what I can do? Beside buying new card
Thanks for help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there,
Have you tried formatting the card?
Best wishes,
M
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yeah, I tried to format by using camera, nothing get changed 😞
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Milauski .
I use this SDXC (https://www.kingston.com/en/flash/sd_cards/sdr) for my FDR-AX33 and have no issues.
Before you buy a new one, check the following things:
1) Be sure that your card uses the exFAT file system that allows recording large files.
2) There is a possibility that your card is a counterfeit.
3) Update the firmware on your camera.
Let us know what happened.
-John
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I would think that the issue is because the card you have is only a class 3 .. basically the card cannot write the information quick enough when you are recording. Get a class 10 card. You can tell this by the number 10 encapsulated in the letter C on the card or packaging. My camera won't record DV video on a class 2 card for the same reason...I put in a class 10 64gb card and it's perfect. Hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi all,
please don't quote the "old" speed ratings (which still use "class") but go for the "new" so called "V"-rating which was introduced for video usage.
In this case get a card with a "V30" rating.
- Nic
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi,I got Sandisk extreme pro U3 class 10 and it also has a V30 mark on it,and it works perfect with 4k!
Also,plese test your card with H2testw to see if it's fake or not,but 100% you'll need a different card!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello @AndyLupescu,
I agree - always test new cards to verify you received a genuine one.
For Sonys 4K camcorders all genuine V30 SDXC cards should work.
- Nic
