Can anyone tell me the model number of the remote commander for the TRV 48E please...I'm in the UK.
Thanks
Hi sadbrewer and welcome.
The Wireless Remote Commander for the CCD-TRV Camcorders doesn’t seem to have a model number. In the user manual showing how to use it, it is just referred to as the wireless remote commander for the CCD-TRV48E. Other components have a model number:-
Hi Blencogo, thanks for the prompt response, my remote actually had the number on it....the trouble is I can't remember what it was, and like an idiot I accidentally threw it out !!
Thanks very much...replacement found on E**y, problem solved.
Thanks again!!
