Sony 8GB Memory Stick PRO-HG Duo HX, is this compatible with my Cybershot DSC-S90
Hi balldad and welcome.
No, your DSC-S90 is not compatible with the 8GB MS-HX8G.
You can check the full compatibility list for MS Media on the support pages for your camera here: -
http://www.sony.co.uk/support/en/product/DSC-S90/compatibility
It seems that it is not fully compatible with anything bigger than the 128MB MSH-128 but seems to accept some cards up to 4GB with certain restrictions.
