Hello, I have a Cybershot W520 and some kind of problem. Sometimes when I use the flash on a camera happens to be only one flash, the second does not, and the picture is quite blurry. Anyone know what it is ... thanks
Hello ivys84 - Welcome to the Sony Forums.
You may have the flash set to the automatic mode - meaning that it will only activate when the camera feels that the natural light needs to be boosted by the camera's flash. When you are composing a shot with your camera, you can press the 'Flash' button on the control wheel (the 'Lightning Bolt' on the right) and scroll through the various flash options. If you find that you need the flash to activate more often to avoid blurry pictures, you can set this logo to always show a 'Flash' icon on the screen.
Thanks,
Simon
