DSC-P93 I have been using a Sony 256mb Memory Stick Pro Duo Magic Gate memory card with an Memory Stick Duo adaptor on my camera but I am finding the storage space too small.
I have researched this and I am getting mixed messages about what I can and cannot use. Can I have some advice please? I know this is old technology and the amount of memory space will be limited but any advice will help.
Message was edited by: MargHarry
Hi MargHarry, welcome to the Sony Forums
You can use a Memory Stick PRO up to 2Gb (MSX-2GS/X) without restrictions. The official compatibilty list is here: http://www.sony.co.uk/support/en/product/DSC-P93/compatibility
Mick
Mick
