How do I set long exposures 15 - 30 secs on my Sony HX-10V
profile.country.en_GB.title
conkelly54
Cannot seem to set this up on my camera via the menus
Message was edited by: conkelly54
1 ACCEPTED SOLUTION
blaireau_photo
Hello conkelly54 - Welcome to the Sony Forums :slight_smile:
With the HX10V camera, you are able to select a shutter speed of up to 30 seconds. This is controlled in the Manual Exposure Shooting menu on the camera and there are full instructions on the following page from the online user guide:
http://pdf.crse.com/manuals/4412220111/ENG/contents/02/03/07/07.html
As long as 'M' is selected on the mode dial, you will be able to press the 'dot' button on the control wheel and then rotate it to choose between 1/1600 of a second and 30 seconds.
Thanks,
Simon
3 REPLIES 3
blaireau_photo
Thanks,
Simon
Mick2011
Hi conkelly, welcome to the Sony Forums :slight_smile:
You don't need to access any menus really, just set the mode dial to M (manual) and select your shutter speed (up to 30s) using the control wheel.
Mick
conkelly54
Thanks Simon
