playmemories for sony dsc-hx90v
keitht1958
i connected camera to usb 2 reinstalled playmemories but it wont connect
it says camera installed to someone else i think its me using old email address which i no longer have access to.
it says to deregister press menu and select initalise to reset user but i cant find this in menu options.
1 ACCEPTED SOLUTION
profile.country.NL.title
Strampke
I'm using the same camera.
Suggest reset the camera and start all over again.
2 REPLIES 2
Strampke
keitht1958
thanks for the tip working now.
