Is there a way to return my HX20v back to its factory settings? My son used it for his art project and now it seems to be taking way too long to take a picture.
Hi Flossie, welcome to the Sony Forums
All Cybershot cameras use the same reset procedure, which won't erase your images, but it's always a good idea to download them first:
(Settings)
(Main Settings)
[Initialize]
desired mode
[OK]
![]() | REC Settings | This operation will reset the settings made at the time of shooting to default settings. |
| All Settings | Resets all settings to default settings. | |
| Network Settings | Resets all network settings. |
Make sure you don't remove the battery pack during the reset routine.
Mick
