I bought a Sony Cybershot WX350 recently but have also had other cyber shots in the past. I was sorting out chargers and have got myself confused which is the correct one for the WX350. One charger is called Model noAC-UD10 complete with lead and a usb cable. The other model is AC-UUD12 which is attached to the plug. Which is the correct one for the WX350 and what is the other one for?
The adapter is simple USB charger. 5V 1500 mA
You can use any Smartphone charger as well. Those have an outut of 5V, 500 mA
There are fast chargers which give 2100 mA and more.
Choose whatever USB charger you have at hand.
